10 or 11 sec 3rd gen owners, in here PLZ
Old Jan 12, 2006 | 07:03 PM
DeHoyos's Avatar
Car: 87 IROC
Engine: "400"
Transmission: Whiplash unit from CVT
Axle/Gears: Bolt-in 9" Moser
Any 10 or 11 sec. 3rd gen owners, please lemme know the specifics of your setup, 1/4 times, actual HP(no guesses plz), and how streetable it is. I am going with fuel injection (HSR) so any EFI tips would help. Thanx, Chris.
Old Jan 12, 2006 | 11:11 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
since you haven't gotten any responses yet, I thought i'd steer you a bit....
I know IHI, and Stephen87iroc are both in that range. Stephen's isn't a street car though. Also a lot of people in the forced induction forum would be as well. Read peoples sigs.
Old Jan 13, 2006 | 05:41 AM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
380 ci motor 4.155 bore with a 3.5 stroke. Ran flat top pistons zero decked. AFR 195 heads, victor jr intake, 750 carb with a solid roller cam dur at .050 in 250 ex 260, lift .680 in .660 ex it worked great on the street with pump gas car ran 11.00s and teens @120to 121 mph on all motor. Horse power at the wheels was 439 hp.
Old Jan 13, 2006 | 07:19 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Apples and oranges. Stephen's car isn't even remotely street legal. For his application, I don't know why he didnt go with a vega or something like that but, he's having fun anyway.
There is a lot of fast cars in the power adder forum.
-- Joe
Old Jan 13, 2006 | 08:11 AM
LnealZ28's Avatar
Car: 1987 Z28
Engine: 383 Single Plane EFI-NOW RUNNING!
Axle/Gears: Not there yet...
Search for threads & posts by 87_TA He's the man. Ran a 10.2x and drove it about 6 hours to the track....................
Old Jan 13, 2006 | 09:27 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
check sig.
355
protopline heads
230/244 .544/.576 on a 112
HSR
T-56 4.11's
This is a n2o set up. Would pull 11.40's w/ a different cam, correct plugs, etc.
Old Jan 13, 2006 | 02:13 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
car in sig with a 150 shot on a 305 got me 11.85- 11.90s
Old Jan 13, 2006 | 08:51 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
I had a 3500 stall cov and a 3.89 gear in the car for the combo I gave you.
Old Jan 13, 2006 | 11:45 PM
DeHoyos's Avatar
Car: 87 IROC
Engine: "400"
I have a 355 short block with 10:1 forged flat tops sitting on the engine stand. I have a .554/ .544 hyd roller cam, HSR w/ 58 mm TB, 38# injectors, and a 10# bottle sitting at the shop. I have 4.10s and need to get a converter for my 700r4. I was thinking (too many things) maybe building a 400, maybe a 383, and/or buying a supercharger. I know i gotta get a tune for whatever I go with.
I know this sounds childish , but my cousin has a 00 GT w/ an ATI putting 400 HP to the ground. He's selling the ATI and going with a Roots setup. I want to be able to beat him and still be streetable.
Old Jan 14, 2006 | 02:02 PM
automec's Avatar
Car: 82 Z-28
Engine: 408
Transmission: TH-400
Axle/Gears: 4.11
i run a 4.165 bore , 3.48 stroke . 379 ci , flat tops 11.1 to 1 comp. dart pro 1 230 heads milled to 59cc chambers. 264,272 duration @ 50 650 lift solid roller cam, 950 hp carb. 4500 stall th400 and 4.11 gears .
have full interior ,4 speaker stereo weighs 3600 lb. with me in it.
it runs 11.3 to 11.4 @120 on motor and 10.32 @ 132.8 on a 150 shot.
runs on pump gas here (4500 eleavation) but i put race gas in it to spray it . and it gets a whole 10 mpg at 65 mph .
my wife drives it to work during the week , and she lets me drive it on the weekends
Old Jan 14, 2006 | 05:09 PM
DeHoyos's Avatar
Car: 87 IROC
Engine: "400"
Anyone running AFR 1040X heads?
Old Jan 15, 2006 | 08:02 AM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
My heads were the 1036 but the 1040 will do the same.And my heads are for sale in the classifieds.
Old Jan 15, 2006 | 04:24 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
11.19@120 with the following.
406
afr 195's
mighty demon 650
10.4 compression
hooker 2210's
victor jr.
mufflex 4" kit
3.73 gears
26x11.5 et streets
3400 stall
TPIS ZZ-X cam (for sale) .559 lift 241@.050
The 60' times were low 1.5's with built 7.5" rear end. This is very streetable. I have driven over an hour to the track to race and then drove home. AT the 1/8th mile track it went 6.70's with a 150 shot of juice and a 1.47 60'. That's roughly 10.50's. The cam is from TPIS and is designed for fuel injection so if you go that route you'll be fine.
Old Jan 15, 2006 | 10:23 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
In sig, streetable beyond belief and expectations. It's made several hour interstate runs over the course of it's life with no problems, same with car cruise parades-no problems. If you build a car to last on the street, the race track is childs play
Old Jan 16, 2006 | 02:46 AM
83 Crossfire TA's Avatar
Originally posted by Free Bird
check sig.
355
protopline heads
HSR
T-56 4.11's
Which protopline heads? Out of the box or ported?
Old Jan 16, 2006 | 08:43 AM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
They are the al. 200cc runner 64cc chambers angle plug. No porting, just a simple gasket match. And I only waited a week for them to show up instead of 4-6 months for AFR's. Not to mention they're cheaper.
Old Jan 16, 2006 | 09:16 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
It seems some people got the usable pro-toplines, others (b4ctom1) got the ones with the un-matchable ports.
-- Joe
Old Jan 16, 2006 | 11:13 AM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
-- Joe
Ya, I read that post. Kinda freaked me out until I found out that the ones he got were apparantly an older casting. These looked very good out of the box.
Old Jan 17, 2006 | 12:58 PM
Cruz'N Bruz'R's Avatar
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
I was just gonna throw a thread up about my Pro Topline 200's. I have the straight plug 64cc head and pulled the valves out to pocket port them, but there's no point to it. they're remakable as cast. Short side radius is smoot, and the valve throat has to be already 85-90% of valve diameter. It's a nice straight shiot to the valve. I think I'll just put them back together.
Good to see someone with good results from them Free Bird.
Oh, and it took me 8 months almost to get mine from New Zealand.
Old Jan 17, 2006 | 02:43 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Traxion had an 11 second "streetable" 350. He was usually pretty secretive about what was in that engine. All I can remember is it was a 350 with milled AFR heads, stock rotating assembly, mini ram, hooker long tubes and some huge cam. He sold it to another member on here. Maybe someone could twist his arm???
Old Jan 17, 2006 | 08:05 PM
DeHoyos's Avatar
Car: 87 IROC
Engine: "400"
What CC combustion chamber size is used to figure piston CR ? Like I have 10:1 flat tops. That is based on using what CC head?
What CR is too much for N20 ? If I used a 150-200 shot, would I be safe with 10:1 or would I need a lower CR?
Old Jan 17, 2006 | 09:07 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
What heads are you using cast iron or aluminum? And what size cam?
Old Jan 17, 2006 | 09:16 PM
DeHoyos's Avatar
Car: 87 IROC
Engine: "400"
Most likely aluminum heads, haven't picked them out yet. Probably something close to an AFR 1040. Cam is .554/.554 (w/ 1.6), 224/224 @ .050, 110 LSA hyd roller.
Old Jan 18, 2006 | 12:39 AM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
check sig.
355
protopline heads
HSR
T-56 4.11's
I'd be interested in your race weight, tire choice at the track, exhaust, and dyno times.
I've got a 355, Protopline 200cc/64cc Iron heads, 10:1CR (8.2DCR),
see sig for cam, etc. With a HSR and pulled ~300RWHP/300TQ and my best ET on street tires is 13.0@107.
Old Jan 18, 2006 | 06:14 AM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
10:1 comp will work good. You can go up to 10.5:1 also. I have set aluminum heads up to 11.25:1 and ran pump gas it takes the right cam and some deburing.
Old Jan 18, 2006 | 07:57 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
11.91 @ 113 here & that's with the 700R4 & the old cam. Check Camaro page link in my sig for specs.
eightsixseven
Dec 16, 2024 01:50 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Jote4805
Aug 25, 2015 06:11 PM
neekolzun
Aug 24, 2015 04:59 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
