HELP! my car won't start!
Old Jan 14, 2006 | 12:33 PM
rainyskiez's Avatar
Car: Pontiac 6000 SE
I have an '88 pontiac 6000 LE. It was running fine on Wednesday, got up Thursday morning and it won't start. Sounds as though it's out of gas, but it's almost full. What could be wrong? I need to try and get this fixed myself. Please let me know if you can tell me what might be wrong. Thanks!
Old Jan 14, 2006 | 01:20 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
This thread won't last long, as this is thirdgen.org, pertaining to the third generation F-bodies, solely.
But, if I had to take a guess, could be fuel, could be ignition. Could be several things. Need a little more info like do you hear the fuel pump prime?
Old Jan 14, 2006 | 01:30 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Well, you kinda NEED spark and fuel in order to start it. Try buying a can of starting fluid, or even carb cleaner will work.
Take of the inlet hose and squirt a little fluid in there while someone tries to start it. If all the sudden it tries to start - fuel pump. If no change, check for spark.
Old Jan 14, 2006 | 04:48 PM
IROCZman15's Avatar
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
whats needed for an engine to run
fuel
air
proper compression
spark
why urs is not running, well we need a little more information...
Old Jan 14, 2006 | 04:49 PM
IROCZman15's Avatar
Car: 1987 IROC-Z
needed to run
fuel
spark
proper compression
air
midge54
Dec 27, 2019 04:14 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
killer777
Aug 8, 2015 02:47 PM
