Intermittent starter issue
Car: 91RS_92Z28
Engine: 5.0_5.7
Transmission: WCT5_WCT5
Axle/Gears: 3.08_3.42
Intermittently my starter will not turn, but the solenoid always clicks when trying.
The starter is less than a year old and when it does start it cranks healthy as new.
Security light is functional but does not light up.
The first time it happened a gave the starter a whack and then it started a short time later. The second time I did nothing but wait and it started.
The curious thing is that the solenoid always will activate but the starter won't turn and it is a very random problem.
Thoughts before I yank the starter?
Transmission: 4L80E/4L80E
If all of your wiring is snug, then it may be the contacts within the solenoid that send power to the motor causing the problem.
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
What Five7kid suggested could be the source of your problem.My '95 Jimmy is doing similar.The starter motor gear is not engaging the ring gear on the flywheel/flexplate.It could be a shim problem also - either starter is to close or to far out.
If your starter is less than a year old then it's probably still under warranty.If after you check all your connections you still have the problem I would pull the starter and take it back to where you bought it.They can test it and replace it then.
TheTraut88
Sep 7, 2015 05:22 PM
