o2 sensor
Old Jan 19, 2006 | 05:20 PM
steve87iroc's Avatar
Car: 1987 iroc z
Engine: 355 dart platinum 215cc heads
Transmission: <<BLOWN UP TH400>>
Axle/Gears: 10 bolt 4.11's
o2 sensor
ok when im driving at a constent speed my engine lite comes on like say im going 55 it will come on but when i slow down it wil go away i was woundering if its my o2 sensor and also when i floor it it seems like its searching it goes for a second then stops then goes and so forth and i sort of smell some gas when i roll the window down.
Old Jan 19, 2006 | 05:23 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Have you considered checking what code it is?
Old Jan 19, 2006 | 05:31 PM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
He's right you won't know till ya check.
Old Jan 19, 2006 | 05:51 PM
Car: 1987 iroc z
can you check even when its not on or will i have to drive the car till it comes on then check it
Old Jan 19, 2006 | 05:57 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
ECM memory stores any codes - they're in there, you just have to coax them out.
A paperclip bent into a "U" will do just this. Bridge the A and B terminals of the ALDL (picture courtesy of Vader):
The SES will flash the codes.
Old Jan 19, 2006 | 05:58 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The ECM stores trouble codes for something like 50 starts after being set.
AutoXray calls them current and history, or something to that effect. In other words, if the light is on, that's a current code; light off, it'll be in history.
Car: 1987 iroc z
is there a place were i can get the codes or what they meen
Old Jan 19, 2006 | 05:59 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
https://www.thirdgen.org/newdesign/f...gen.shtml#misc
They're in there. Scroll down just a bit, you'll see them.
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
