Can't keep engine running
Old Jan 23, 2006 | 01:37 PM
Zero's Avatar
Car: 1988 Camaro
Engine: 5.7 liter motor
Transmission: Four speed automatic
My iroc doesn't start at all sometimes (no dashboard lights, starter or fuel pump). When it does, it'll idle but when I shift to forward or reverse, it shuts off. What gives???
Old Jan 23, 2006 | 02:03 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
any codes thrown?
my gut feeling is electrical/computer.
Old Jan 23, 2006 | 03:47 PM
Zero's Avatar
Car: 1988 Camaro
None. I tested it like my chilton's repair manual said, but it didn't give me anything. Would the ECU
need to be replaced???
Old Jan 24, 2006 | 06:49 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
I would check batt connections. Also check engine ground connection/s. Look for prev repairs to the wiring system under the hood.
Vintageracer
Jan 10, 2020 05:33 PM
theshackle
Mar 5, 2017 06:37 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
camaroken83
Aug 10, 2015 11:35 AM
