TPI or Carb?
Old Jan 23, 2006 | 05:37 PM
SaintedCorrupt's Avatar
Car: '85 TA
Engine: Carb'd 350, ported 416s
Transmission: retrofitted T5
Axle/Gears: 3.42 7.62" 10-bolt, locker
am i retarded for even asking?
I'm looking to see whether it's gonna be worth it to swap out my carb for the TPI that's taking up space in my garage.
I am currently running a mild 350 with an Edelbrock 1405 mech. secondary carb on and originally cc Quadra-bog fuel system, so it already has a return line.
I have the complete TPI manifold and matching computer, but i will need to rob some unsuspecting junkyard car of it's wiring harness. The carb was originally computer controlled, so i already have all or most of the sensors around here somewhere. there was already a holley red pump in the car at one point(noisy freakin thing), so i could just pop it back where it was.
Would this swap be worth the effort (power, fuel consumption, and anything else y'all can think of wise) of a installing an electric pump and an engine wiring harness, or should i just try a rebuild on my old Eddy?
Old Jan 23, 2006 | 07:06 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
idk, but i may be putting a tpi into my v6, so if you decide to sell your setup let me know... Good luck with your car
Old Jan 24, 2006 | 02:04 PM
Car: '85 TA
cool, i'll let you know
Old Jan 24, 2006 | 02:36 PM
ljnowell's Avatar
If it were me, and I needed a new carb, I would just get a new carb. TPI is nice. It has its ups and downs. As far as performance goes though, it has too many downs and not enough ups. Stay carb.
Old Jan 24, 2006 | 03:05 PM
Car: '85 TA
problem is, new carbs arent exactly cheap. unless you wanna get a holley off ebay and rebuild it, but frankly, i dont trust myself in that matter. i learned on FI and thats what i'm good at. on the other hand, i like not having to drop the gas tank to get to my fuel pump.
Old Jan 24, 2006 | 04:48 PM
iroczracer07's Avatar
Car: 1989 Camaro
Engine: 350 but it's torn down right now.
Axle/Gears: I'm working on it,lol.
T.P.I. is good for fuel economy and easy starting, but the induction system is based off of the 305 T.P.I., which is restrictive to say the least. If your 350 is mild, you might consider getting a Holley Street Avenger with vacuum secondaries and electric choke in the 600 cfm range. That should be more than enough to keep you happy. If cost is a factor though, it probably would be cheaper to put on the T.P.I., but be warned, the induction system in it's stock form could provide a little more low end grunt, but you'll pay for it by 4500 rpm's when the induction kills your mill's power making capabilities. Hope that helps.
Old Jan 24, 2006 | 09:08 PM
89IrocZ350TPI's Avatar
Car: ws6
Engine: ls1
Transmission: m6
For a street car tpi works and with just bolt ons is capeable of running deep into the 13's. If your looking to get into the 12's ditch the tpi and go with a carb or aftermarket intake. TPI runs out of revs quick.
Old Jan 25, 2006 | 06:18 PM
Car: '85 TA
[i]... If your 350 is mild, you might consider getting a Holley Street Avenger with vacuum secondaries and electric choke in the 600 cfm range.... [/B]
I'm running a T5 right now, wouldnt that be bad with vacuum secondaries?
Old Jan 25, 2006 | 06:55 PM
ljnowell's Avatar
A mechanical secondary carb would be nice, better for performance. However, many people run vacuum secondaries with a manual. Its not "bad" its just not optimum.
gta90
Sep 15, 2015 04:00 PM
beachrodder
Aug 25, 2015 08:05 AM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
