tc lockup - 305 chip in a 350?
Old Jan 23, 2006 | 07:48 PM
huntingwood's Avatar
Car: 1989 Trans Am
Engine: l98
Transmission: 700 R4
Axle/Gears: 10 bolt with 3.23s
My car originally had a 305 tpi, but the previous owner swapped in a 350. When I'm cruising at about 30 mph, it feels like the converter locks because the car starts chugging really low and feels jerky. Is the speed for lockup different on the 305 chip than on the 350 chip? I am wondering if it is possible that the previous owner just left the original 305 chip in there? Thanks for any help.
Old Jan 23, 2006 | 10:07 PM
Vader's Avatar
Lockup/unlock MPH settings changed from year to year for even the same engines. They may be different depending on what gear you are in as well.
Old Jun 3, 2006 | 02:06 PM
Car: 1989 Trans Am
Engine: l98
Well it's been awhile, and I'm still having the same problem - this definitely doesn't feel like it should be locking up at this low of a speed, the car lugs along really rough when it locks. I guess my question was if its even possible for a 350 car to run on a 305 chip? Should I find a serial number or something on the computer that could tell me?
Old Jun 4, 2006 | 12:23 AM
Car: 1989 Trans Am
Engine: l98
Also, I've noticed that the car seems to be running rich - from some of the reading I've done here, it seems like that would happen if it was a 305 chip because its for #19 injectors, and I've got #22s. Anyone?
Thanks!
Old Jun 4, 2006 | 11:50 AM
Vader's Avatar
You can cheak easily by lowering the ECM,. removing the access cover for the MEMCAL, and reading the broadcast code on the foil label on the PROM. Usually, you can see most of the label through the holes in the MEMCAL cover:
Jake_92RS
Jan 28, 2020 10:37 PM
bamaboy0323
Sep 3, 2015 06:07 AM
NWAsonoma
Aug 18, 2015 05:45 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
