head gasket choice
Old Jan 25, 2006 | 11:38 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
head gasket choice
on my 383 in my sig, i want to run nitrous and in the future , some kind of boost, more likely procharger.
is thier any particular headgasket i should look into that works well against nitrous or supercharging over a stock gasket?
Old Jan 25, 2006 | 11:51 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Try a copper head gasket if the surfaces are perfectly flat with alittle hylomar. Or you could go with the new gas filled o-ring head gaskets that don't require any heads or block maching.
Old Jan 26, 2006 | 12:00 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
gas filled? sounds expensive
Old Jan 26, 2006 | 12:03 AM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
I think around $400. But they are cheaper than machining for o-rings and are reuseable.
Old Jan 26, 2006 | 12:06 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
whats the next step down lol i dont want to spend that much on gaskets.
Old Jan 26, 2006 | 12:10 AM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
You probably won't need o-rings unless your going to run massive amounts of boost.
Old Jan 26, 2006 | 12:13 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
i planned no more then like 9psi at most, im running high cr.
anyways though, is thier specific gaskets out thier for nitrous applications?
3rd gen money
Sep 8, 2015 11:40 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
