another oil pressure gauge question.
Old Jan 26, 2006 | 07:45 PM
hoogabooga's Avatar
Car: '68 corvette '73 Corvette
Engine: 427 454
Transmission: TH400
i just read purg3d's post about mech. oil pressure gauges. i have one on my 85 that is plugged in behind the intake. my 85 doesn't have the computer in it but my 86 does. is there somewhere else i can hook it to? my 86 has something (i assume it is the stock sending unit) attached at that hole. it has 2-3 wires coming out of it. can i do away with that without causing comp. problems?
Old Jan 27, 2006 | 11:35 AM
Damon's Avatar
There is also a fitting in the side of the block just above the oil filter that is also used for oil pressure. It's a much bigger thread, though (1/4" NPT vs. 1/8" NPT up on top, if memory serves). Obviously, it will have a plug in it right now if it's not being used by some other/additional oil pressure sensor.
You could use that if you have the right fittings to adapt to it or you could build yourself a "Y" fitting from parts store pieces up on top of the motor and run both the factory sender and your mechanical gague off the same port.
Old Jan 27, 2006 | 11:59 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: another oil pressure gauge question.
You may have a sender with a switch in it for your fuel pump relay.
check schematics before you take it out.
Old Jan 27, 2006 | 04:54 PM
hoogabooga's Avatar
Engine: 427 454
Transmission: TH400
thanks for the replys. if i can get it running again i will try those ideas.
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
