codes 12, 13, 24
Old Jan 27, 2006 | 01:48 PM
Camarothunder85's Avatar
Car: 1985 Camaro IROC-Z
Engine: 350ci V8
Transmission: 700-R4 auto
codes 12, 13, 24
What do they mean?
Old Jan 27, 2006 | 02:43 PM
Engine: 350ci V8
Scratch that. After running a search I found the answer. My question now is could code 24 and my speedometer not working be related? Also My car is a 85 IROC with TPI. Do I have a dash mounted VSS or tranny mounted VSS or both?
Old Jan 27, 2006 | 03:18 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Code 24 IS the VSS which means the speedo isnt working.
Dash VSS
Old Jan 27, 2006 | 03:28 PM
Engine: 350ci V8
Thank you.
Old Jan 27, 2006 | 04:20 PM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
Yes, 24 Vehicle Speed Sensor. Same problem with my car. Got a new VSS sitting on the shelf ready to install. Note, this part goes into the side of the Trans (700R4 in my car).
Old Jan 27, 2006 | 04:47 PM
Engine: 350ci V8
Which one do I need? The one in the tranny or the dash?
Old Jan 27, 2006 | 06:10 PM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Who knows. The VSS is in the Tranny. The dash has the speedo only. It could be the VSS, Speedo, or the Cable.
Old Jan 27, 2006 | 06:34 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Firebirds & 90 and up Camaro have the VSS in the tranny, Camaros 89 and older run the cable and the VSS is in the dash.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
