Taking Her to the shop
Old Jan 27, 2006 | 11:00 PM
RST89's Avatar
Car: 1983 camaro
Engine: 2.8...... 3.8t coming soon or should I do a ls6 almost the same cost hmmm.....
Transmission: 3spd soon to be either a 700 or t56....
Ok i found a local chevy expert works mainly on vettes and our and only chevys really clean shop and trustworthy. So what do you guys think my problem will be. here are the symptoms.....
1983 camaro 2.8 2bl electrnic carb w/ 3speed tranny
aprox 8mpg
dieseling off
hesitation from stop to WOT
check engine light on constant wont give ay codes from jumping the adl
really hesitant when starting first thing in the mornings
when at highway speeds the volt and choke light flash as soon as i turn on blinkers or lights it goes out.
this is what i have done to fix it so far.....
New carb installed new gaskets and adjusted
tested controll mod
found and fixed all vaccume leaks
replaced computer
checked all fuses including ecm computer exe exe
What that fixed......
NOTHING any one have any ideas?? thanks ill let you knwo what it really ends up being
Old Jan 27, 2006 | 11:48 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Transmission: Tremic6060
Axle/Gears: good enough
Let me know what you find out! i'm haveing the same troubles... exept for the choke light comming on! im gonna watch this thread with intrest
Old Jan 28, 2006 | 12:24 AM
RST89's Avatar
Car: 1983 camaro
lol will do it is getting dropped of tomm so it will be cold for him on monday morning as soon as i get the results i will post them. every one on here over the past few weeks keeps telling me check for vaccume leaks and there are no more leaks so we will see.
Old Jan 28, 2006 | 01:07 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
dieseling typically indicated timing that is too retarded causing run on after the engine is shut off. I would check that as well. Remember to pull the one wire connector as well to pull out computer timing when using a timing light. It's a brown-ish wire near the master cylinder or by the A/C evaporator depending on what year car it is.
Old Jan 28, 2006 | 07:14 AM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
EGR valve and or a cloged intake passadge to it.
Old Jan 28, 2006 | 08:27 AM
RST89's Avatar
Car: 1983 camaro
egr could do all that?? wow let me add this peice of information i forgot to mention.... all of these symptoms happend over night and progressively got worse. with exception of the choke and voltage light flashing that is new. one day it was fine the next morning it was doing all this crap. so i do not think it is timing but at this point who knows lol thanks for that so far!!
project89
Sep 24, 2015 06:38 AM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
Kevin91Z
Sep 16, 2015 03:00 PM
neekolzun
Aug 24, 2015 04:59 PM
jackhammer
Aug 15, 2015 10:04 PM
