Hot CD Ignition & Ignition Module
Old Jan 30, 2006 | 03:09 AM
Siggy's Avatar
Car: 1988 Camaro IROC LB9 F
Engine: 305 HO EFI
Transmission: TH700R4
Axle/Gears: GU5 LS 3.23
I recently blew, cooked (silicone baked good) a Delco ignition module after 12 months of running.
I did a search on the form and found many ICM failures for apparent different reasons. My setup is using a Crane Hi6 CD ignition (multi-spark) with a high energy coil and stock Delco ICM in my 305 TPI.
Now my plugs are gaped at .065" (plus wear & carbon) which is very large and I suspect that this high resistance used with the high energy ignition is just too much current for the Delco ICM?
I will replace with a new Delco ICM and regap to .040
or .045" and hope.
Can anyone offer words of wisdom, opinion or has had a similiar expeirence.
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
BumpaD82
Feb 26, 2016 02:57 PM
Racerx974
Sep 19, 2015 10:16 AM
BLK87Z
Sep 18, 2015 11:29 PM
