Engine Boggs Unless In Park
Old Feb 3, 2006 | 02:09 PM
alivenkickin29's Avatar
Car: 1989 Trans Am
Transmission: 7004r
guys,
i have an 89 Trans Am with the 305TBI engine - idles pretty good, not great when you have it in park but as soon as you start off to go it stutters and bogs which doesn't let the transmission shift right - if you stomp it you get total bog down - you can hold it half throttle and it will eventually get a little power to get up to about 55 but thats about it -- I seem to have pretty good exhaust flow coming from the tail pipe -- but what could this be? HELP!
Old Feb 3, 2006 | 02:32 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Start with the basics. Do you have any SES codes? Check plug wires. Check timing. Check for spark on each cylinder. Get a fuel pressure guage ($10 at Advance), install in-line, and check fuel pressure. Replace fuel filter (another $10). Check firing order, and check for vacuum leaks.
A general tune up is the best place to start.
Old Feb 3, 2006 | 03:10 PM
Car: 1989 Trans Am
Transmission: 7004r
engine bogg unless in park
I pulled the SES codes and all i get is code 23 -- Mixture Control Solenoid - what is that and where is it?
Frozer!!!
Jan 19, 2024 04:55 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
