STRANGE...Slave Cylinder Cover hits tranny tunnel now...wont fit
Old Feb 4, 2006 | 11:46 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
i pulled my motor a while ago leaving the tranny in the car. just two nights ago i got the new motor in but found out the cover that the clutch slave cylinder bolts onto wont line up because it hits the underside of the car!!!!!
its like something shifted or something but i am ABSOLUTLY CLUELESS
anyone have any input/suggestions at all??
Old Feb 4, 2006 | 01:59 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Are you talking about the bellhousing? What all was pulled with the engine, and what was left in?
Old Feb 4, 2006 | 02:18 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
im talking about the metal cover the slave cylinder bolts to (i have a 1991 T5 BTW). when i go to bolt up the slave and the cover to the bellhousing the cover hits the floorboard and the bolt holes cant line up.
if i came down to it, i could always just do without the cover and bolt the slave up with nuts and bolts but this problem makes me think something else might be wrong...why in the hell is this not going abck on!?!?!
when i pulled the motor i left the bellhousing on the tranny and left the tranny in the car.
its like the tranny needs to shift to the pass side a little bit or it needs to rotate clockwise (when facing the car)...
Old Feb 4, 2006 | 04:34 PM
Lo-tec's Avatar
How did you get the trans input shaft to go into the clutch correctly while dropping in an engine? It's not bad doing it this way with an auto, but can't comprehend how this is possible without screwing up something. It takes some wiggling just to stick a T5 back onto the bellhousing and line up the shaft into the clutch when the engine/bellhousing are bolted together in the car. I would guess the bellhousing isn't mounted flush to the engine.
Old Feb 4, 2006 | 08:14 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
thats what i thought but the belhousing is perfectly flush. if the input shaft isnt lined up properly there is no way the bellhousing can be flush but mine is.
im so lost...
Old Feb 4, 2006 | 08:32 PM
Lo-tec's Avatar
time to post some pics to see what's going on
Old Feb 4, 2006 | 09:27 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
the corner of the cover is hitting at the x.
Old Feb 4, 2006 | 09:28 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
see
Old Feb 4, 2006 | 09:29 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
the bolt holes wont line up
Old Feb 4, 2006 | 09:35 PM
rustybluebird's Avatar
Car: 87 Firebird
Engine: 350, 416's, 230/230 cam, torkerII, q-jet
I think you have it on bacwards, ins't the sheild suposed to go on the same side as the slave?
Old Feb 4, 2006 | 09:45 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
let me go check
maybe i need to lay off the...
Old Feb 4, 2006 | 09:58 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
suspicions confirmed...im a dumbass. you know three guys labored over that for two days. too many late nights.
the problem was the cover got bent at the end and wouldnt fit over the slave the way it was supposed to. so i use "common sense" and say well the cover should be there to protect the slave arm and fork...a quick rap with the hammer and it slipped on perfect
thanks, that had me confused
1992 Trans Am
May 10, 2023 07:19 PM
db057
Aug 22, 2015 08:17 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
