won't start after first few tries
Old Feb 6, 2006 | 11:56 AM
88ragtop's Avatar
Car: 88 sport coupe convert
Engine: 305 tb
Transmission: auto
My 88 305 would barely turn over so I replaced the battery. After I installed the new battery it will turn over and start but if I kill it right then and try again it barely turns over and may not start. Could it be the starter. It does always try to turn over not just a clicking noise.
Old Feb 6, 2006 | 01:17 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Verify batt cable and ground connections. If they are good, it's most likely the starter solenoid. You can try replacing that, or just replace starter (which usually comes with a new solenoid).
If you plan on keeping the car for a long time, might wanna consider a gear reduction starter. They work a lot better and last a lot longer. Especially on modified engs.
Derick15
Sep 17, 2016 05:28 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
EFR2000
Aug 18, 2015 08:54 PM
