upgraded cam and spark timing
Old Feb 7, 2006 | 03:35 PM
Firebreather's Avatar
Car: 1991 GTA
Engine: SuperRam 350
I heard I should advance more the spark if I'm using a hotter cam than stock. Perhaps because of the earlier open valve event? The thing is I am running at 14 degrees of initial timing right now with no knock and the car feels as it could benefit from a slightly more advance timing. Maybe it's just a the need of steeper gears. Anyone?
Old Feb 7, 2006 | 07:58 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
14* of static timing seems like alot of timing. Have you set the timing correctly by disconnecting the EST wire? (I forget sometimes, but it is apparant that something is wrong with the timing jumping all over the place)
If yes, if you think that you can use more static timing, then bump up the static timing by 2*, if you get pinging at WOT or any other load case, bump it back 2*.
This is not the best time of year to do this WOT testing because of the colder weather (assuming you are in the North).
Old Feb 8, 2006 | 09:08 AM
Car: 1991 GTA
The EST wire was disconnected. It never gets cooler than 60* around here. No pinging at all at 14.
Frozer!!!
Jan 19, 2024 04:55 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
gta90
Sep 15, 2015 04:00 PM
cstrobel65
Aug 15, 2015 10:19 AM
