Early Trans Am 3190 Curb weight
Old Feb 7, 2006 | 06:32 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
I found this interesting.
Old Feb 7, 2006 | 07:16 PM
89IrocZ350TPI's Avatar
Car: ws6
Engine: ls1
Transmission: m6
Yeah that is interesting.
Old Feb 7, 2006 | 07:34 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
The older cars actually were several hundred pounds lighter than the 91-92's. But that seems alittle optimistic for a firebird.
Old Feb 7, 2006 | 08:05 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
What made them lighter then the 91-92s?
When you say optimistic for a firebird, do you mean compared to a camaro? Or compared to thirdgens?
Old Feb 7, 2006 | 08:09 PM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
Transmission: Built 700r4
early thirdgen's actually were simpler, therefor less weight. the older cars came stock with fiberglass hoods, the brackets on the serpentine cars weighed more, less electronics.
Old Feb 8, 2006 | 11:58 AM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
This is the e-mail I got back from Mecham.
"Curb weight is not the vehicles total weight. It is the number the factory uses as a base weight for the car. I'm not sure in what state that is,( no options, etc.) but it is the weight used to determine shipping around the country for the car. We didn't do anything to lower the weight of the cars in the base packages. Truth is with our added equipment, larger tires, wing, suspension braces, etc. the cars probably weighed 75 lbs. or so more than a standard car."
Old Feb 8, 2006 | 12:03 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
My 82 camaro z28 with most options came in at 3296 curb weight via the invoice.
...just for reference
Old Feb 11, 2006 | 01:36 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
wow that does seem pretty light.. i wanna get my car weighed. i figure 3500--3550 with me in it i hope
Old Feb 11, 2006 | 11:27 AM
Car: ws6
Engine: ls1
Transmission: m6
I think the stock L98 cars weigh at 3456 give or take.
Old Feb 12, 2006 | 12:05 AM
BLUETA's Avatar
Car: 86 TRANSAM
Engine: 406
For reference, when I bought my 68 Camaro brand new, I looked
at the weight as listed in the GM literature. The Camaro listed at
2925 lbs (The Corvette at 2975 lbs). The actual weight was 3215
lbs, 1/4 tank of gas, no driver. The car was a v8, 4 speed, no a/c
and no power steering or power brakes. So 300 lbs sounds about right.
84z96L31vortec
Aug 20, 2017 12:16 AM
Reddeath210
Oct 6, 2015 08:20 AM
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 23, 2015 03:49 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
