can someone give me hp/tq numbers
Old Feb 7, 2006 | 06:44 PM
slapi01's Avatar
Car: trans am
Engine: sbc350, afr 180cc head, comp full roller, xtrem 276,comp 1.6 roller rockers,weiand142
Transmission: tremec tko
Axle/Gears: 8.5 3.73 gear, moser 30 spline axles,eaton posi
here is what i am working with
sbc 350, 9.1-1 pistons, afr 180 76cc heads,(everything roller) comp cam xtreme276 lsa112 .503/.510, 1.6 rockers, weiand 142 with stock pullies with the flow of the heads i think i might end up with 4lbs of boost
total comp should be around 8.2-1 with the heads. anymore info needed ask away.. thanks guys
Old Feb 7, 2006 | 07:38 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Probably around 450hp for a guess.
Old Feb 7, 2006 | 08:19 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
around 400-420hp/420-440tq @the crank. With your set up especially the heads which will flow decent along with a stock pullied 142 roots will give you about 4-5psi which is not a whole lot of boost...probably if your CR was like 9:1 or 9:5:1 with that amount of boost you'd make more power. The way to go is keep your 8:2:1 CR and get a smaller pulley for the blower, I think the 142 maxes out at about 10psi and with lower CR and more boost you make more "total" power and not as succeptable to detonation in the process.
Old Feb 7, 2006 | 08:23 PM
SleeperFromHell's Avatar
Car: 92 RS Vert, 86 Iroc
Engine: Blown 350
Transmission: Slushbox
Problem is can the 142 pump enough air to make big power? I had a huge war about this already in the F/I board but i say go for it. I'd like to see what the 142 can do with your setup.
Old Feb 7, 2006 | 08:46 PM
the most you'll get from a 142 especially on a good breathing 350 is 500 @ the crank MAX. That is with the very smallest pulley weiand has for it and spinning it that fast, you're gonna build ridiculous heat not to mention shortening the life of the blower.
Old Feb 7, 2006 | 09:34 PM
Engine: Blown 350
Agreed.
Bohemian
Aug 15, 2017 05:11 PM
earlpote
Sep 12, 2015 11:55 AM
J.C. Denton
Sep 8, 2015 05:35 PM
john204481
Sep 7, 2015 03:22 PM
