question of the day how to turn a 350 to a 383
Old Feb 10, 2006 | 08:42 PM
formulafastfoot's Avatar
Car: i have a 2003 ford zx2 and a 1989 f
Engine: 350 tuned port, 4 banger on the Z
Transmission: 700r4 poop loser
Axle/Gears: 3.23 standard ...one tire fire
im wondering how you turn a 350 into a 383 ive got a stock 350 and would like to know what i need to buy to turn it into a 383 thanks for your info
Old Feb 10, 2006 | 09:33 PM
Lunatic0987's Avatar
Car: 89 Formula 350
Engine: 355
you need a .030 bore on the block. And you need a 400 crank. There is also some machining that has to be done to the block for clearance and such that im not to sure about. Someone with some more knowledge will fill in the blanks.
Old Feb 10, 2006 | 09:41 PM
ljnowell's Avatar
Not necesarily a 400 crank, just a crank with a 3.75 stroke. Personally I dont think I would bother with a 400 crank when you can get an aftermarket cast steel crank for under 200 bucks.
The machining is required on the main journals. The 400 uses a bigger journal. They grind it down to the 350 main size.
The work doesnt end there though. You will have to clearance the block and usually rods also. Many people run a small base circle cam, to aid in clearance.
Old Feb 10, 2006 | 09:44 PM
383T/A's Avatar
Car: 84-88 Pontaic Trans Am Convertable, 88 S-10 350, 89 S10 2.5L
Engine: 383 - 475 hp 485 ft lbs
Transmission: WC T5
Axle/Gears: 9 Bolt
I used a aftermaket 383 crank, 383 pistons and cam clearanced 5.7 rods. You may have to remove some material from the block to clear your rods. There are many more variables when building this or any engine.
Old Feb 10, 2006 | 10:04 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Using a 400 crank is just stupid and to much of a hassle for nothing. What you want is a 3.75" crank with 350 journals, aka a 383 crank.
MustangBeater20
Oct 29, 2022 09:20 PM
apo_bailon15
Mar 28, 2016 05:20 AM
redmaroz
Aug 16, 2015 11:40 PM
sreZ28
Aug 14, 2015 07:48 PM
Fronzizzle
Aug 9, 2015 01:15 PM
