what are the physical diffrances in noisy and quiet gear drives?
Old Feb 12, 2006 | 06:53 AM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
I just got a dual idler gear drive off E-bay, it was somthing the person i bought it from had laying around, he wasen't sure of the brand, but he said it was a quiet unit, is there any way for me to tell who made it and if in fact it is a quiet one?, the number on the box is TG-350, thanks in advance
Old Feb 12, 2006 | 07:47 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Noisy gear teeth are cut straight across the gear, quiet are at an angle.
Old Feb 12, 2006 | 08:03 AM
Engine: 383
ah, crap...I was afraid of that...these are strait cut..
Old Feb 12, 2006 | 08:16 AM
Engine: 383
I just did allitle searching of all the ones on E-bay, they all seem to be strait cut...noisy and quiet....one even had a pic of the box that said quiet...intresting...not to dobut you five7, but is there any chance this is a quiet one??
Old Feb 12, 2006 | 11:10 AM
ljnowell's Avatar
YOu may see some that are quiet that have strait teeth. Lots of these have a composite covering over the teeth of the gears. These are not quiet, they are quieter. Helical (angle) cut gears are the ones that are quiet. With those however, you will have to run some sort of cam button, because they produce end thrust.
jklein337
Sep 19, 2018 06:23 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
