car starts and then stalls
Old Feb 15, 2006 | 10:22 PM
1991_maro_RS's Avatar
Car: 91 camaro rs
Engine: 305 tbi
Ok, i have a 1991 camaro rs with a 305 tbi. last winter i rebuilt the engine and after i reinstalled it it ran fine for 3 or 4 months. then all of the sudden when i try to start it, it will just cranks and cranks then it will start and then die immediately. it will do this 8 or 9 times before it will start ad run. then after that it runs fine. i have done a lot of tests on the computer and fuel systems. it has come down to a lack of fuel problem and it has a new fuel pump in it. when it starts and dies the injectors are only trickling fuel. i have been working on this problem sence october so if anyone out there has had a similar problem or just has some advice i would very much appriciate it.
Old Feb 17, 2006 | 05:28 PM
Annihilator's Avatar
Car: Caprice
Engine: 5.0 305 LO3
Transmission: 2004-R
I am experiencing the same problem. I also have a newer fuel pump installed. Anyone have any suggestions?
Old Apr 19, 2006 | 11:56 AM
Brent C.'s Avatar
Car: 89 GTA.
Engine: 357
Transmission: 700 R4
Axle/Gears: 3.23 I think?
X3....any help? mine is a 350TPI mass flow.
Old Apr 19, 2006 | 12:13 PM
bobdole369's Avatar
Car: 1989 Firebird
Engine: 2.8L V6 MPFI
Transmission: Beat to heck 700R4
Bad new fuel pump, restriction in the fuel lines up to the injectors, ECM not telling the injectors to fire, fuel filter, fuel pressure regulator, fuel pump relay could all cause this. Use a fuel pressure gauge and try the ALDL connector to force the pump on.
Wade787b
Sep 29, 2015 01:15 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
killer777
Aug 8, 2015 02:47 PM
drathaar907
Aug 6, 2015 04:20 PM
