stupid angle plug head question
Old Feb 16, 2006 | 04:34 PM
TPIs-10's Avatar
Car: 88 S-Dime
Engine: 388
are the locations of the spark plug hole in the same spot on all angle plug heads- both factory and aftermarket? the reason i ask is because i am doing another v8 engine swap in my s10- and from what i have read- it's just about impossible to find a set of headers to fit angle plug heads. i have a set of hedman long tubes for the project. i also have a set of 113 heads (they are just left over from something else- not planning on using them on this swap). just out of curiosity i held the headers up to both heads- and i don't think there would be any problems with angled plugs- looks like straight plugs would be more of a problem. just trying to make sure the plug locations were the same on all head suppliers- before i went and ordered the wrong thing.
Old Feb 16, 2006 | 05:23 PM
eXesiv|83ta's Avatar
Car: 1983 Pontiac Trans AM
Engine: 355 chevy
Transmission: 700R4 Built
Axle/Gears: Built 10 bolt 3.73 gears
Re: stupid angle plug head question
I bought dart angle plug heads and with my hedman long tube headers I have to pull the headers off the head to service a couple of plugs. Quite a pain in the ***.
Old Feb 16, 2006 | 06:05 PM
TPIs-10's Avatar
Car: 88 S-Dime
Engine: 388
was this on your third gen or on an s10 v8 swap also? it looks to me like the more of an angle the better- as far as getting to the plugs is concerned. if i do have to take a header off to get to the plug- that would suck- but it would be better than the header not fitting at all because of the plug.
Old Feb 16, 2006 | 06:33 PM
Vader's Avatar
Tried angle plugs?
Sorry, I had to.
Old Feb 16, 2006 | 06:41 PM
TPIs-10's Avatar
Car: 88 S-Dime
Engine: 388
da*m you- for a second- before i scrolled down- i was thinking to myself- are you kidding me- i have never seen such a thing before. you of all people- one of the most knowledgable guys on here.......
thanks for that
Old Feb 16, 2006 | 09:06 PM
Engine: 355 chevy
lmfao
Ya sorry it was on my trans am. The headers might be different for an S10. lol.
Old Feb 16, 2006 | 09:12 PM
TPIs-10's Avatar
Car: 88 S-Dime
Engine: 388
ya- that's what i get for asking an s10 question on a fbody site
Old Feb 16, 2006 | 09:17 PM
Engine: 355 chevy
hehe ya pretty much. But it might be the same because a V8 in a S10 is gonna be pretty tight. The headers are going to be closer to the heads than would be in a larger engine compartment. I guess I would just check it out, if you have the headers check the distance between the flange and the closest part of the header to get a better idea. Sorry I can't help more.
Old Feb 16, 2006 | 09:30 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
To answer your question, the spark plug location is not in the exact same location or angle on angle plug heads. Same for straight plug heads.
Old Feb 17, 2006 | 06:41 AM
TPIs-10's Avatar
Car: 88 S-Dime
Engine: 388
shat- why can't anything be simple. guess i will have to call dart and hedman and tell them what i would like to do- see if they can help out a little.
Old Feb 17, 2006 | 07:55 AM
Moving the spark plug is an inevitable result sometimes of improving the design of the heads.
If everything about all aftermarket heads was the same as stock, then there wouldn't be much point in their existence in the first place, now would there.
Old Feb 17, 2006 | 08:22 AM
TPIs-10's Avatar
Car: 88 S-Dime
Engine: 388
good call
CRFred
Feb 7, 2016 11:39 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
