can a remote mount coil be mounted upside down?
Old Feb 17, 2006 | 03:05 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
i have a 1991 z28 TPI...i didnt think the coil had to be mounted right side up but am not sure. can anyone chime in and let me know?
mounting it anyway i want will really open up some options...
Old Feb 17, 2006 | 03:17 PM
Doesn't matter. Whatever way you want.
Old Feb 17, 2006 | 03:18 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Its basically just a transformer... Coils of wire... So yeah, you can mount it any way you want.
Old Feb 17, 2006 | 07:43 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I have mine mounted upside down. When I put the HSR on the car, there wasn't any place to put it so I mounted it to the cowl,
Old Feb 17, 2006 | 10:06 PM
thirdgen88's Avatar
Car: 1995 Corvette
That's right where the hood weatherstripping runs though...
Old Feb 17, 2006 | 10:18 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
rip it out. Then you'll have cowl induction
Old Feb 18, 2006 | 10:33 AM
Zepher's Avatar
My hood is opened up in the back, but I don't really see an issue with the stock hood since the weather stripping is rubber.
Old Feb 18, 2006 | 12:59 PM
gp423's Avatar
Car: 1989 Firebird Formula
Engine: LB9 305 tpi
Axle/Gears: open 2.73's baby!!
can taking the weather stripping off cause a problem with anything under the hood? like if it rains and some water gets back there?
Old Feb 18, 2006 | 01:21 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
yes...if you're getting water coming in from behind there it can affect the dizzy possibly, the coil depending on where you mounted it, and whatever else electrical you have near there.
i dont plan on driving in the rain so i dont even have wipers
Old Feb 19, 2006 | 01:55 AM
Zepher's Avatar
not sure about your engine bays, but all of my electrical connectors are of the weatherpack style with rubber seals.
The only thing not 100% weathersealed is the distributor since the bottom ridge of the cap is the only portion that seals it from weather, but I don't see that as a problem.
I'll snap a shot of the engine bay from the drivers seat so you can see how open the back of my hood is.
My car is a daily driver and Virginia is by no means a dry state. It rains a lot here.
83 Crossfire TA
Jan 3, 2016 01:26 PM
FormulasOnly
Sep 6, 2015 10:42 AM
SG91camaro
Sep 5, 2015 10:27 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
