Would this work?
Old Feb 18, 2006 | 04:51 PM
WaaX's Avatar
Car: 1985 IROC
Engine: 350 TPI (block was swapped)
Transmission: 700r4 w/corvette servo
Axle/Gears: no idea
Would this work?
I deleted the blower motor and box when I deleted my ac system a long time ago, I regret doing so but its not too much of an inconvenience, just have to bundle up a little warmer.
My friends blazer who im pulling a 350 out of has a blower box that looks like it MIGHT fit with some modification. Im not scared of fiber glass because my friend patt works with it all the time.
http://img486.imageshack.us/img486/1220/dscf13548sc.jpg
would that work?
Old Feb 18, 2006 | 05:05 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Different size. You'll have to do alot of fiberglassing.
Old Feb 18, 2006 | 05:35 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
When I "deleted" the air conditioning out of my Firebird, I installed two 12v electric windshield defosters so they blow hot air up into the origional defroster ducts under the dash.
Normally these heaters plug into the cigarette lighter for power.
I Hard-Wired them into the origional OEM fan switch on the dash.
Ya can't tell. They give off enough heat to defrost the windshield and take the chill out of the car for cold nights or mornings. You can buy these auxillary electric defrosters from most auto parts stores or JC Penny.
The discharge temp of these 12v dashboard defrosters is about 100F.
two of them is enough to get the job done for all but extreme cold.
Old Feb 18, 2006 | 05:59 PM
Car: 86 T/A
Engine: HSR 355
That's pretty awesome. I only drive my car 6 months of the year, so that'd work very well if I didn't already have the AC delete box.
Old Feb 18, 2006 | 06:31 PM
WaaX's Avatar
Car: 1985 IROC
Axle/Gears: no idea
Where did you actually place them? That seems like a perfect idea, My mom actually used one of those back when her heater core went and I never thought about that because I havent actually had to drive my camaro in the snow yet *im lucky, kinda*
Old Feb 18, 2006 | 06:38 PM
F-BIRD'88's Avatar
When you remove all the heater ac stuff leave in the defroster duct work. then mount the heaters unde the dash so they blow into the defroster ducting and up to the windshield. I hard wired them into the heater/ac fan switch allowing me to turn 1 on only, or both at once and protected them with a inline 20-30amp fuse.
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
