balancing crank
Car: 1987 iroc-z
Engine: 355
Transmission: t5
Axle/Gears: 7.5" 4.10
balancing crank
i was wondering if anyone has any advice about balancing a 3.75 scat cast stroker crank it is setup from scat for external ballance but i talked to a machine shop guy and he said that if i don't ballance the motor it will have enormous vibrations i am wondering what to do for it i have arp reconditioned rods a set of kieth black hyp pistons THANKS
Car: 1986 Trans Am
take it to a shop and have them balance it, otherwise the motor will vibrate itself apart. Im pretty sure you might need some special equipment for balancing.
Car: 1988 iroc/2000 saab 9-5
Engine: 355 tpi/Roller cam
Transmission: 700r4/2800 stall,megashifter
Axle/Gears: 3;42
Geez id kill for a stroker eng for my 88,
intrnal balance like mentioned,worth it
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Internal/external balance isn't the same as having the rotating assembly balanced. All internal or external balanced cranks mean is where the mass of the weight is located. Externally balanced cranks don't have the extra mass in the counterweights so it's added in the balancer and flexplate/flywheel.
The crank counterweights are at an estimate weight. To properly balance the weights, the machine shop needs balancer and flexplate/flywheel (if externally balanced), con rods with bolts, pistons, rings and rod bearings. All these are weighed and the crank's counterweights are balanced to compensate for the weight of the rotating assembly. All the rods are adjusted to the same weight and so are the pistons. Knowing where to remove excess weight is part of balancing.
Because of different piston and rod weights, a crankshaft is never properly balanced. Unless you're building a stock engine with stock components, an engine should always be balanced.
When I had my 540 balanced, I got an internally balanced crank. All 454+ cranks are normally externally balanced. Because of the lightweight rods and pistons in my engine, the machine shop had to fill one of the factory balance holes in the crank.
If a rotating assembly isn't balanced, an imbalance can hammer out the crank bearings especially at high rpm. The weight of the rods, pistons etc need to balance out the counterweights on the crank.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: crank
Originally posted by stroked377
why do they seel it as a externaly ballanced crank then do they intend for people not to have to ballance it
skinny z
Oct 5, 2015 06:23 PM
monte87cortez
Sep 26, 2015 08:10 PM
