computer controlled cam
Old Feb 20, 2006 | 06:44 PM
stroked377's Avatar
Car: 1987 iroc-z
Engine: 355
Transmission: t5
Axle/Gears: 7.5" 4.10
i am going to keep the tpi setup and i am swapping my cam do i have to stay with a computer controlled cam ?
Old Feb 20, 2006 | 06:49 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
cams are not computer controlled. wtf do you mean?
Old Feb 20, 2006 | 06:52 PM
stroked377's Avatar
Car: 1987 iroc-z
Engine: 355
Transmission: t5
please someone with some brains and not a huge temper
Old Feb 20, 2006 | 06:56 PM
Dialed_In's Avatar
I don't have a temper, I just didn't understand your question
Old Feb 20, 2006 | 06:58 PM
forever3's Avatar
Car: 88 IROC
Engine: 5.7 L98 TPI
Transmission: 700 R4
Dude, I am still learning, but I was calling around today, and acording to Comp Cams, he said I can keep all my stock equipment, including my computer, and put a bigger cam in with no problems. Another member had posted on here that one big thing to watch is keeping your 112 degrees of lobe seperation. This will keep the vacum high enough at idle that the computer wont wig out on ya. Even a 110 deg cam will mess with ya a bit. I am still working on lift and duration. I have seen alot on here about a zz4 cam, but not REAL sure what is up with that. Looks like it will require better valve springs.
Try a search on "zz4 cam"
Hope that helps.
Old Feb 20, 2006 | 07:00 PM
stroked377's Avatar
Car: 1987 iroc-z
Engine: 355
Transmission: t5
i am looking to find a cam that will work well with my tpi and i was told that i should stay with a computer controlled cam so i do not have stalling and driveability issue's is this true
Old Feb 20, 2006 | 07:02 PM
stroked377's Avatar
Car: 1987 iroc-z
Engine: 355
Transmission: t5
great that is very helpfull with the whole lsa info and all thank you
Old Feb 20, 2006 | 07:40 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
There are cams designed with stock-type EFI in mind. Comp Cams has a line of XE cams specifically for TPI motors. Go check it out!
Old Feb 20, 2006 | 09:26 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
I think they meant you need a cam designed for computer controlled engines. I believe the '87 has a roller cam (uses roller lifters.)
I have a '88 IROC 388 non-roller TPI with the XE262H-14, heard ZZ4 is not really designed for TPI, but will work with MAFs. I'll probably bump it up later, but it has to pass emissions.
Old Feb 20, 2006 | 10:53 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
A cam designed with EFI in mind will run better than one picked off the shelf. EFI needs to have things like duration, overlap, and ramp rates controlled differently than carb engines can get away with.
Comp will tell you which cams will work with EFI. Listen to their advice.
Old Feb 21, 2006 | 10:14 PM
forever3's Avatar
Car: 88 IROC
Engine: 5.7 L98 TPI
Old Feb 22, 2006 | 01:12 PM
sully91rs's Avatar
Car: 91 RS, 95 Z28
Engine: 305 tbi, 350 lt1
Transmission: 4l60, 4l60e
Axle/Gears: monsterous 2.73s in both
After rgarcia assuemed what he was asking, I understand. But on first reading, i thought
Old Feb 22, 2006 | 02:57 PM
stroked377's Avatar
Car: 1987 iroc-z
Engine: 355
Transmission: t5
ok thanks i guess i'll start by calling comp cams
Old Feb 22, 2006 | 04:00 PM
five7kid's Avatar
I've had better results by emailing them. Don't have the time limitation that a tech support type has on phone calls. Be sure to give them all details about your combination, including the engine size, modification (porting, for instance), exhaust, transmission, rear gears, car weight, intended use, etc. - the more, the better.
Also be aware that their recommendations are typically conservative. They'd rather take a chance with you having slightly less power than ending up with something that doesn't drive well.
eightsixseven
Dec 16, 2024 01:50 PM
midge54
Jan 29, 2017 07:00 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
theurge
Aug 21, 2015 12:46 PM
