MSD 6A, 6AL, or not?
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
was wondering about the pros/cons of adding one of those boxes to my ignition system for a slightly modified engine, as in bigger cam and more lift (about .525).
Transmission: 4L80E/4L80E
The factory ignition needs some kind of help. You may not need to go as far as one of those boxes, but getting one of those boxes will do the trick. A destinct advantage is the added rev limiter capability.
Car: '91 Z28
Axle/Gears: 323's
i've got MSD billet distributor and coil on there, along with the 8.5 super conductor wires, but i was thinking the 6A or 6AL box would help the spark out a bit...
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
five7, I thought factory spark setups were alright? Not going as far as the box then, what upgrade would you recommend? just a beefy coil?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
An aftermarket coil and module is probably enough. As long as the cylinder ignites there's probably not a lot more power to be gained with upgraded ignition components.
Car: 1982 Trans-Am
I thought a "module" was that box. Ie, an MSD6... hmm, better bone up on my terminology.
Okay, okay, okay. All 'stick said in the original post was "slightly modified engine". No mention that one of those mods was an MSD distributor.
MSD distributor means no more factory module.
On the other hand. . .
MSD box also means no more factory module.
If you don't need rev limiter capability, still have a factory distributor, then an aftermarket performance module and coil are probably all you are going to need.
How much a module costs depends upon the distributor you have. The 7-pin large-cap HEI modules go for $50-$60.
Blaster coil needs to be the right type. Otherwise, yes, it's fine.
Car: '91 Z28
Axle/Gears: 323's
SO... would the recommendation be to just go with what i've got, meaning the MSD dist and coil and no box?
Car: '91 Z28
Axle/Gears: 323's
and that"s why it says "GM" on it? of course the flip side says "singapore"
anyhow, what'd be a good after-market module?
Car: 82 trans-am
Engine: 305 4bbl q-jet
I have a question guys. My cousin gave me this msd ignition coil for my car the part number is msd8225. My car is an 82 transam with a 305 in it, the ignition system is stock. I checked around and that coil will work fine. My question is, can I use a stock ignition module with it or do I need to upgrade and what can I use that will work.
Chris
Chris
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
