Oil Pressure Keeps Moving Around
Old Feb 24, 2006 | 11:24 PM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
Transmission: 700-R4
Axle/Gears: 3.27 9-Bolt
OK, im driving along and I start to hear beeps, i look around, no lights on, so i ignore it.
So, i slow down at a red light and it happens again, I happen to look at the Oil Pressure Guage, and it's at 0, then immediately rises back up to around 30, and starts to hover between the two numbers, while at idle.
When im driving normally the pressure usually tops off near 60, but when I slow down somewhere at a light or whatnot, it drops low again.
The car drives perfectly fine when the pressure at 0, so im guessing it may be the Oil Pressure Sending Unit?
Old Feb 24, 2006 | 11:33 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Normal
Old Feb 24, 2006 | 11:36 PM
llvll4l2c91350's Avatar
I have the same problem. i think i read on here it has to do with the oil pickup screen coming loose inside the oil pan. i think vader posted it.
Old Feb 24, 2006 | 11:40 PM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
So how do I go about getting this fixed?
Old Feb 24, 2006 | 11:59 PM
https://www.thirdgen.org/techbb2/sho...t=oil+pressure
drop the pan, put it new oil pump with pickup and something to attach both together so they dont come apart. Jegs sells a metal brace just for this purpose.
i am not worried about mine enough yet to make me drop the pan.
Old Feb 25, 2006 | 12:27 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Eliminate the simple stuff first.
Old Feb 25, 2006 | 03:40 AM
Keepin This One's Avatar
Car: 1988 iroc/2000 saab 9-5
Engine: 355 tpi/Roller cam
Transmission: 700r4/2800 stall,megashifter
Axle/Gears: 3;42
i would keep it simple;
remove sender, hookup psi guage, verry cheap,
plum it into sender, hose n fittings, see what you got.
89GTAOz
May 16, 2020 09:31 AM
db057
Aug 22, 2015 08:17 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
