Starting an old engine?
Old Feb 26, 2006 | 01:21 PM
$5003rdGEN's Avatar
Car: 1984 Camaro SC
Hey everyone, I recently bought a sport coupe with a 70's 350 in it, and lately have been able to spend some time on it. My problem is, I just can't get the engine to fire up. When I bought the car, we were able to pour gas down the carb, and it would run just as long as you were pouring gas into the carb. I figured that the carb was to blame, so I drained the gas out of the tank, replaced the carb, and now it wont even fire, except for a backfire or sputter here and there. I am bypassing the gas tank via a rubber hose and a can of gas. Same thing. A little sputter here and there. Here are the engine specs if that helps...
350 with a .284 duration cam, Q-jet, stock intake and straight pipe. Stock distributor too.
Old Feb 26, 2006 | 01:24 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Sounds like the fuel pump is shot. Does it have fuel pressure? Does it fill the carb bowls when you crank it?
Old Feb 26, 2006 | 01:40 PM
$5003rdGEN's Avatar
Car: 1984 Camaro SC
It does have pressure. When we bypassed the tank, we pumped out any bad gas in the fuel pump. Do you think the plugs could be shot?
Old Feb 26, 2006 | 01:47 PM
Lo-tec's Avatar
Pull them and find out. What's the timing at, do the wires look rough, etc etc. Also, are you using a known good carb?
Old Feb 26, 2006 | 02:02 PM
$5003rdGEN's Avatar
Car: 1984 Camaro SC
I'll go and pull the plugs, and see whats up. The carb is just a stock replacement Q-jet I bought from advance auto parts. All the wires look to be fine. The timing hasnt been touched really. Thanks for the help, too!
Lo-tec's Avatar
Hasn't been touched and correct are two different things!
Old Feb 26, 2006 | 02:08 PM
$5003rdGEN's Avatar
Car: 1984 Camaro SC
thats true. I don't really know how to tell you. I havent worked with ignition systems much.
Old Feb 26, 2006 | 06:31 PM
$5003rdGEN's Avatar
Car: 1984 Camaro SC
-I got it running!!!!!!! Thanks for your help!!!-
Old Feb 26, 2006 | 07:06 PM
Lo-tec's Avatar
Please post the reason it didn't want to run...and the fix...for the next guy that runs into the same problem.
Good Job getting it running!!
Old Feb 27, 2006 | 05:56 PM
$5003rdGEN's Avatar
Car: 1984 Camaro SC
Problem: Car wouldn't start
What I did to fix it:
_________________________________________
1.emptied the gas tank of old gas
2.bought new carb.
3.Checked for spark
4.cleaned distributor terminals and all contact points
5.changed the plugs
I think that the plugs were mostly to blame, but the bad gasoline and mis-adjusted carb definately did NOT help.
Thanks again, lo-tec for helping me get it to run!
Old Aug 1, 2009 | 08:27 AM
B's 92 camaro's Avatar
Re: Starting an old engine?
i got a problem i have a 92 camaro rs with the 305 tbi my starter keeps engageing even though i am not turning the key it starts but the starter stay turning do i need to shim the starter or is it just bad starter
Old Aug 1, 2009 | 09:44 AM
astrosurfer's Avatar
Car: 84 trans am
Engine: 305 5.0L HO
Transmission: TH350
B's 92 camaro....
A new topic would actually get you more help.
You need to find out where the starter is getting the power to the solenoid when the key is not in the start position.
Prob a bad relay or something. Might even be a bad ignition switch.
The solenoid should have no power with the key in any position but start.
But maybe I will stand corrected. There are truly some ace guys on here and they will help with all their hearts coz they love 3rd gens.
If I was you I'd make a new topic bud.
Frozer!!!
Jan 19, 2024 04:55 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
