help my car is leaking oil
Old Feb 26, 2006 | 01:22 PM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
well today im driving my car and i notice the oil pressure gauge is reading 0 at a stop or when im going very slow. it goes up to 20-25 when im driving at normal or high speed. so i looked under my car and it is leaking motor oil little my little. i looked were it coming from and it hard to see its runing down the oil filter housing maybe by the drverside of the engine. has this happen to anyone and can you tell me what to look for thanks. it a 350TPI
Old Feb 26, 2006 | 02:58 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
how much of a leak is it? best thing to find out for sure where it is comming from would be to clean the area up as best as you can then drive it. you should see new oil from somwhere. this cleanup means both above and below where you think it might be. oil does weird things when leaking.
if it is just a small leak I doubt it is going to cause much of ap roblem though still would be best to fix.
another thing with the oil prssure is it might be related to the sending unit. best way to find out is either just replace the sending unit or hook up a mechanical gauge to double check the pressure rather then depend upon the chinsy cheap GM part
Old Feb 26, 2006 | 04:12 PM
Car: 91 formula
its leaks very slow. like a bad sink would leak but not as rapped. i think i added maybe alittle to much oil when i but some in the car but its not much past the full mark
Old Mar 11, 2006 | 07:01 PM
82_t/a_305's Avatar
Car: 1982 Trans Am
Engine: 305 H.0
Transmission: th350
sounds to me like either an oil pan gasket or the rear main seal
Old Mar 11, 2006 | 08:33 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
if its leaking down the filter housing the rms and oil pan gasket are out of the question due to the way gravity works. Most likely its a valve cover gasket leaking.. but it's all mere speculation without actually being able to look at it..
Old Mar 11, 2006 | 08:48 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
You had poor oil press reading, and thats when the leak showed up? Is the sending unit leaking?
Old Mar 13, 2006 | 12:43 AM
ShadowWulf's Avatar
Car: 1991 Trans-Am
Transmission: Manual
Axle/Gears: Unknown
Check the sending unit, i just replaced mine when i bought the car as it was leaking like craze out of there. Cheap and easy fix.
Another option....jack the car up and take a rag to the underside and clean off every oil soaked piece. Then start it up let it run a minute or so and crawn under it after its shut off and try and find the leak then.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
TheExaminer
Aug 26, 2015 04:59 PM
MY87LT
Aug 17, 2015 08:43 AM
Exxon Limited
Aug 9, 2015 08:13 PM
drathaar907
Aug 6, 2015 04:20 PM
