Full Ignition
Old Feb 26, 2006 | 02:04 PM
bbq014's Avatar
Car: '88 IROC
Axle/Gears: 9", Locker, 4.10's
Full Ignition
I'm planning on doing a full MSD ignition (Distributor, Box, Coil, Wires, Plugs) on my 305 TPI.... any one done this before or have any reccomendations on parts to get?
Im basically confused on which distributor to get and if i should get a vacuum or mechanicall advance.
Also I wanted to do the remote timing control that i could adjust from the drivers seat... any suggestions?
Old Feb 26, 2006 | 02:14 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Re: Full Ignition
Why?
They should have a direct replacement distributor, just get that one. I would get a 6AL box b/c it has a rev limiter in it.
Old Feb 26, 2006 | 03:35 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
MSD has a distrbutor specifically for the computer controlled TPI engines. Thats the one you want. The MSD part number is 8366. It is for 1987-1993 cars. It is just a plug-and-play deal for a TPI car... drop it in, hook up the factory wiring, and go (from MSD's website)
Old Feb 26, 2006 | 04:09 PM
bbq014's Avatar
Car: '88 IROC
cool, now with the 6al box and the msd gm blaster coil that should be everything i need to upgrade the ignition (besides wires and plugs) right?
Old Feb 26, 2006 | 05:18 PM
Air_Adam's Avatar
Should be. The distributor for the TPI engines doesn't say it needs an ignition box like alot of the other dissys do, so you probably don't need it. Just the coil, wires and plugs.
Old Feb 26, 2006 | 06:01 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Like said above, the 8366 is a drop in. You don't need a box, but it's nice to have one. A little better burn and a rev limiter.
Old Feb 27, 2006 | 02:32 AM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Does MSD make an 8-pin hei module for use in that dizzy? All I've found is their take on a 4-pin module, which won't work with the computer controlled diz. Also, does it come with the special gear for use with roller cams?
Old Feb 27, 2006 | 09:40 AM
bbq014's Avatar
Car: '88 IROC
cool guys thanks a lot
Tim
Hotrodboba400
Dec 10, 2019 07:07 PM
ericjon262
Sep 11, 2015 06:07 PM
Jlanz55
Sep 6, 2015 02:35 PM
SG91camaro
Sep 5, 2015 10:27 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
