AC starts the car
Old Feb 26, 2006 | 10:48 PM
KamaroKyle91RS's Avatar
Car: 1991 Chevrolet Camaro RS
Engine: 350 TBI Small Block V8
Transmission: Automatic
AC starts the car
I've got a 91 RS with a 350 TBI and I've been having problems getting it started. The car will only start if the air conditioner is on. If i turn the AC off while the car is on it will die.
Is the solution to this a new starter? I've been wondering about the throttle kicker relay. Any feedback would be greatly appreciated.
Old Feb 26, 2006 | 10:58 PM
Vader's Avatar
First, do you mean the engine won't crank if the AC is not on? Or, will it crank but not run?
AFAIK, there is no throttle kicker on an EFI engine. Extra idle for load compensation from an AC is done with the IAC. The ECM will add a specified number of steps or increase the target idle RPM when the AC is turned on.
Have you cleaned the throttle body lately?
Old Feb 26, 2006 | 11:07 PM
It won't even crank.
Old Feb 27, 2006 | 01:09 AM
stitchop's Avatar
Car: 91 firebird
The solution is not a new starter, if it will start the car, it is working. However,there is something stange going on with the ignition wiring or the ECM
Old Feb 27, 2006 | 01:28 AM
Dracul's Avatar
Car: 1983 Camaro z28
Engine: 5.7
Transmission: 5spd
ok this just isn't fair.. i wanted to somehow make a kill switch doing the exact thing you have going wrong.. and i was pretty much told it was gonna be too much of a pita.. please when you figure out what it is that is doing it, let me know so i can make my car like yours..
Wade787b
Sep 29, 2015 01:15 PM
86Base
Aug 8, 2015 01:34 PM
Sherpajames
Aug 7, 2015 06:56 PM
L98GTA87
Aug 5, 2015 11:02 PM
