Question For You Camshaft Guys....
Old Feb 28, 2006 | 10:01 AM
ndamron's Avatar
Car: 82 Trans-Am / 83 Trans-Am
Engine: Major Mod SBC / Minor Mod SBC
Transmission: Major Overhaul 700R4 / Stock 700R4
Axle/Gears: None!!! / 3.73 posi disc...soon
I have a 427sbc with 3000 stall
Old cam: 242/248 @50, .571/.577 @50, 110LSA
New Cam: 254/260 @50, .582/.588 @50 110LSA
Both cams are solid Rollers
With the old cam installed my car idled just like a stock 305, im wondering what you guys think the idle will be like with the new cam.
~Nick~
Old Feb 28, 2006 | 10:37 AM
Is this a test?
Ummm..... a stock 350?
Do I get my cookie now?
Old Feb 28, 2006 | 11:13 AM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
hahaha
Old Feb 28, 2006 | 07:51 PM
klumb15's Avatar
here ya go..
Attached Thumbnails Question For You Camshaft Guys....-chocolate_chip_cookie.jpg
Old Feb 28, 2006 | 08:04 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
I have a 434 sb and I am using a little bigger cam. Don't ask how it sounds I have'nt heard the motor run yet still waiting for my cylinder heads. cam specs Lift I .688 E .672 Dur at .050 I 270 E280 On a 110 lobe sep. I used a cam simular to the new cam you are installing in a 380ci motor every thing looked close except the lift I .680 E .660 dur at .050 was the same and it was a 110 lobe sep also. It ran great very good on the street and had some hit to it.
Old Feb 28, 2006 | 08:42 PM
ndamron's Avatar
Great, thanks for replying Ross.
~Nick~
Old Feb 28, 2006 | 08:52 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
What heads and comp. are you using? How fast are you trying to go with it ?
Old Feb 28, 2006 | 08:55 PM
ndamron's Avatar
check my signature.....up on the top of the post.
~Nick~
Old Feb 28, 2006 | 09:05 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Hay Nick the cam specs I gave you was made up for the dart 227s with 11 to 1 comp. Those heads flow some good #s And I think you would be better off with .650 lift but that is just me. If you have the cam maby switch to a 1.6 ratio rocker. How fast did this last combo go for you?
Old Feb 28, 2006 | 09:08 PM
ndamron's Avatar
well i honestly cant tell you how fast i was able to go since i blew apart my rear end, and then the tranny went. My problem with going with that much lift is that i dont know if i have the piston to valve clearence. I also am worried about loosing a lot of compression if i go to that much lift, im only at 10.5:1 as it is.
~Nick~
Old Feb 28, 2006 | 09:15 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
The comp will be fine if you keep the dur down like you have. Piston to valve may be an issue as well as valve spring and trust me on this one buy the good spring if you are running on the street.
Old Feb 28, 2006 | 09:16 PM
ndamron's Avatar
I bought everything comp cams told me would be the best, its just the cam was a bit weak for my tastes.
~Nick~
Old Feb 28, 2006 | 09:26 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
On a side note the 700 r4 is going to be hard on a tire if it stays together and If you ever have a chance and means at the track try a 950 hp carb on that pee wee. Are you going with a power adder ?
Old Feb 28, 2006 | 09:30 PM
ndamron's Avatar
all natrual for now, and yes i would like to try a 950 demon carb.
Was thinkin 4.30 gears
~Nick~
Old Feb 28, 2006 | 09:34 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
I like the holley and proform stuff but that is just me. And I think the 4.10 or 3.73 will work great with a 28 in tall tire use the torq.
Old Feb 28, 2006 | 09:38 PM
ndamron's Avatar
well more then likely i will be switching to the TH400, i just really liked the over drive for longer trips.
~Nick~
blackroc68
Sep 1, 2015 08:01 PM
midge54
Aug 29, 2015 09:51 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
Jake_92RS
Aug 17, 2015 09:42 AM
redmaroz
Aug 16, 2015 11:40 PM
