alternarter- amp
Old Mar 5, 2006 | 12:24 PM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
alternarter- amp
hi, i have a 85 tpi camaro, dont know wat type of alternater i need cuz i dont have the orginal? is there any down side to using a alternator that puts out alot of amps, like 200 amps? will i frie my electrical system?
Old Mar 5, 2006 | 01:42 PM
BlkBird408's Avatar
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
Any parts store should be able to tell you what alternator your car needs!!
Old Mar 5, 2006 | 04:04 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
down side? huge $, perhaps burning out faster.
If you just need a stock motor, a junkyard or partstore alt for your car is what you want.
If you want higher output, you can try going to a CS144, or a powermaster aftermarket style alternator, but only if you have a huge stereo, or other electrical gizmos added.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
