no more pcv valve...is this bad?
Old Mar 5, 2006 | 11:17 PM
355tpipickup's Avatar
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
this may be a stupid question but im askin anyways....would it be a bad idea if i took off the pcv valve and just put in a breather in its place?
Old Mar 5, 2006 | 11:27 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
yes leave the pcv system in place, your car is no faster by removing it and it helps oil vapors as well.
Old Mar 5, 2006 | 11:28 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Their is nothing to gain by not running a PCV system, you can only loose by not running one.
Old Mar 6, 2006 | 01:07 AM
Car: 92 1500p\u 2wd
sounds good i wont touch ti then...thansk
Old Mar 10, 2006 | 10:44 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Axle/Gears: 8.5", 3.42
If you're going for the look of breathers (which do look better IMO), you can get a breather that has a nipple to attach the PCV hose to. I don't believe it has a check valve in it like a PCV valve.
If you were to use a normal breather you are going to get some oil vapor venting into the atmosphere when there's no, or next to no vacuum, like WOT runs.
My '71 Camaro suffers from this. Although it does keep my valve covers from rusting.
tyeo098
Nov 30, 2015 06:27 PM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
CatmanFS
Sep 19, 2015 09:00 AM
gta892000
Sep 16, 2015 12:40 AM
