a few q's on valve covers...
Old Mar 11, 2006 | 07:50 PM
Trah84Z's Avatar
Car: 1984 Z28 ~Brown Horse~
Engine: 305 V8
Axle/Gears: 3.23...i dunno...
so i found out that whomever owned the car before me had the driver's side valve cover on backwards (the oil filler cap is toward the front of the car) and i have to take off the whole air filter stuff just to add oil so, when i go to switch it back around, do i have to get a new gasket or is there anything else important i should know?
and if i decide to get new ones, is there really a difference between center bolt and side bolt? i have side bolt ones, will i have to change anything? which ones are more preffered?
Old Mar 11, 2006 | 08:52 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
New gaskets are recommended yeah, theyre cheap anyways. Go with rubber over cork. I like side-bolt covers, I just dont trust centerbolts to seal. Other than that you shouldnt have issues, just clean up the gasket mating surfaces when you get it off, and torque it decently. Don't go overboard, dont wanna warp/stretch anything. Stick with what ya got, and just get a set of rubber gaskets IMO, and a razor blade to clean the surfaces of old rubber/rtv that may be there.
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Yes you need new gaskets. You can only run the side bolt covers. Your heads will only accept that style.
SPEEDY Z28
Brakes
16
Apr 18, 2016 02:46 PM
sleprock
Sep 24, 2015 04:33 PM
HikoriYami
Sep 21, 2015 07:11 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
