Head Gasket Selection
Old Mar 11, 2006 | 11:03 PM
WaaX's Avatar
Car: 1985 IROC
Engine: 350 TPI (block was swapped)
Transmission: 700r4 w/corvette servo
Axle/Gears: no idea
Im looking on summit for head gaskets and ive noticed that they have different bore sizes. My 350 has been bored over thirty thousandths so would I want the bigger 4.200 in. bore or do I want the standard 4.166 in.
*edit*
i would use the search feature but i cant :\
Old Mar 11, 2006 | 11:28 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
You want the smallest bore size gasket that doesn't overhang the cylinder bore.
The bigger the bore size of the gasket the smaller the border between cylinders. Gaskets are made to fit the "most" applications to cut costs.
400 block +.030 overbore = 4.156 , gasket size 4.166
400 block +.060 overbore = 4.186 , gasket size 4.200
350 block +.030 overbore = 4.031 , gasket size 4.060
350 block +.060 overbore = 4.061 , gasket size 4.100
So you can see that a 4.200 "will-fit" any of these applications, but will not be ideal except for one.
Old Apr 17, 2009 | 01:34 PM
Morit's Avatar
Car: Firebird 88
Engine: 406
Transmission: th400
Axle/Gears: 3.50
Re: Head Gasket Selection
What would happen If I use a 400 gasket on a 350 engine..?
I assume some compression loss, but might be that small that it would not matter..?
And it should not shorten the gaskets life..?
(yeah, I know, an old thread ;-) )
3rd gen money
Sep 8, 2015 11:40 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
