T-56 starter queston
Old Mar 12, 2006 | 02:00 AM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
OK...I know this has been addressed before...but the search feature is inop., I know the factory starter won't work W/a T-56, and your supposted to use a LT1 starter, but will a mini-starter work?, factory starters can barly turn my engine over, and I'm tiard of burning them out and having "heat soak" issues whith them. I was looking at powermaster P/N 9600, would that be a good choice, or is there other options? by the way, it is a small block 355, whith 10.75:1 compression ,also it needs to clear hooker long tube headers. thanks in advance
Mark
Old Mar 12, 2006 | 08:24 AM
BOTTLEDZ28's Avatar
Transmission: A4
Im running the stock starter with my T56. Just get one for a 305. The stasrters for the 350 have a bigger bell on them I believe. I have no issues at all with the starter interferring with anything.
Old Mar 12, 2006 | 11:04 PM
Engine: 383
will an aftermarket mini starter work, the factory starter can't turn over my engine properly, and I don't think it will fit whith the hooker longtube headders I have, and plan to put on
Old Mar 13, 2006 | 05:38 PM
BOTTLEDZ28's Avatar
Transmission: A4
I cant answer that and I would like to know as well since I am in the same boat as you.
Old Mar 14, 2006 | 10:09 AM
Engine: 383
btt
Old Mar 14, 2006 | 11:56 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
FYI the LT1 starter is a ministarter.. I see no reason why an aftermarket ministarter wouldn't work..
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
