pulling engine without emptying air conditioning???
Old Mar 12, 2006 | 03:08 AM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
My engine needs to be pulled out of the car for a rebuild.
I would like to keep my a/c as it works very well, however what is it freeon? the old stuff... is illegal in canada, cant buy it.
Is there any way to pull the engine without having to disconnect the a/c unit? Or am i saying goodbye to a/c because im not going to bother having it converted.
Old Mar 12, 2006 | 05:33 AM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
it's no prob at all, all you have to do is un-bolt the compressor, and leave the hoses attached, DO NOT losen the bolt that holds the hoses to the compressor, and lay the compressor off to the side, being careful not to kink the hoses, not much more to it
Old Mar 12, 2006 | 10:56 AM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Thats what my mechanic does.
Old Mar 12, 2006 | 12:24 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
You can always get it converted to r-134a for about $50 in the event you vented the r-12 into the atmosphere... although I wouldn't vent it intentionally
Ghettobird52
Jul 5, 2024 11:18 PM
Vintageracer
Jan 10, 2020 05:33 PM
TheExaminer
Aug 26, 2015 04:59 PM
jackhammer
Aug 15, 2015 10:04 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
