Nothing works?
Old Mar 12, 2006 | 06:14 PM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
Nothing works?
I just installed a new converter, and pulled off the intake and put it back on. Also re-routed some of the engine bay wiring. wires run under the brake booster instead of over.
Heres the deal. I put in the battery and I dont have power to anything inside the car. No lights, nothing comes on. (cant start car)
Any ideas?
The ground from the battery to the block is fine, aswell as the ones that connect to the back of the head.
Old Mar 13, 2006 | 05:44 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Check the wiring down by the starter. Specifically the large wires that connect to the same post as the pos batt cable. Some cars have fuseable links in those wires.
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
