2 head gasket questions
Old Mar 14, 2006 | 02:31 PM
shawntmartin's Avatar
Engine: ZZ4
Transmission: TH-350
Axle/Gears: 3:73
1.) Is there a head gasket for aluminum heads with a compressed thickness between .041 & .051?
2.) If not, which would you go with for a high performance street car?
.041 = 10.2 Compression ( Octane problems?)
.051 = 9.96 Compression
Old Mar 14, 2006 | 02:39 PM
Engine: ZZ4
Axle/Gears: 3:73
my mistake
My fault...I didn't account for the smaller bore of the .051. The .051 gasket gets me 10.02:1 CR which is good for me. The only thing I guess I would ask now is...is the 10.23CR too high for 93/94 octane?
Old Mar 14, 2006 | 03:04 PM
Guest
Guest
Posts: n/a
On aluminum heads? No.
Old Mar 14, 2006 | 03:07 PM
ljnowell's Avatar
Re: 2 head gasket questions
I really dont think you will run into issues at 10.2 with aluminum heads. Use premium, be happy.
Old Mar 14, 2006 | 04:07 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The stock Vette L98 aluminum head head gasket is .051" compessed. Ask for a set of gaskets for a '90 - '91 Corvette at your local Chevy dealer.
Back in '91 the part number was: 14088948
RBob.
Old Mar 19, 2006 | 01:18 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
You're certainly going to be right near the edge. But with good tuning should be ok. Select a spark plug that is slightly cooler in heat range than what the stock corvette L98 motor calls for. A non projected tip plug helps too. Give the motor no more timing than it needs. If 32 will do it use 32deg.
Old Mar 20, 2006 | 10:06 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
It would be helpfull if we knew what cam you were using. The static compression is less important than dynamic. Are you stating the dynamic compression?
NinjaNife
Aug 23, 2015 11:49 AM
lakeffect2
Aug 23, 2015 08:44 AM
NWAsonoma
Aug 18, 2015 05:45 PM
