Just got A 1967 327!
Old Mar 28, 2006 | 10:45 PM
  #51
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
I guess that would work well, its going to be a workout slamming through all the gears fast though!
But thats just another $1000+ you have to spend on the car that you wouldnt if you went with a larger cube motor.
Old Mar 29, 2006 | 12:45 PM
  #52
1991L98G92's Avatar
Car: 91 Z28 24th Anniversary
Axle/Gears: Posi 3.23
First off, the 302 was designed for a specific purpose...SCCA racing. If cubic inch was not a factor, It would probably have been a 350.
Second, I think this would have served the initial poster better in the History/Restoration section. For someone building an old block for a restoration, it's money well spent. You would get a more positive response and probably better info from members who are more aware of older parts and designs. And, would rather see an engine restored to correct configuration. Yes, if you are looking to build a performance engine for a performance car, a newer more advanced engine would be the way to go.
Like was told to me by and auto instructor former racer, there's no substitute for cubic inch and cubic dollar.
Old Mar 29, 2006 | 01:14 PM
  #53
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Build it! Theres nothing wrong with a 327 unless you dont like beating mildy modded TPI 350's and the hot rod LO3's
Old Mar 29, 2006 | 02:09 PM
  #54
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Originally Posted by ljnowell
I dont agree with this at all. Engine displacement is a HUGE FACTOR in output. A 302 with the same heads, cam, etc as a 400 will never make as much power, certainly not within 1%.
It will make the same peak hp within 1%. The average and peak torque will be way different along with average hp.
scottmoyer
Sep 7, 2015 07:06 PM
84 TA NV
Sep 6, 2015 08:02 PM
Mickeyruder
Sep 2, 2015 02:45 PM
hayesaw0210
Aug 23, 2015 11:15 PM
85cam
Oct 12, 2000 07:52 AM
