Oil and Oil Filters
Old Mar 19, 2006 | 04:23 PM
barrelracr87's Avatar
Oil and Oil Filters
I have had my 92 Camaro for about 3 Months and it is now time for an oil change...well since im a girl and we have some real jerks around here I was wondering what kind of oil and oil filters are supposed to be the best for this car. It's a 305V8
Thanks!!!
Old Mar 19, 2006 | 05:45 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Good change would equal 5 quarts Mobil 1 10w-30 and a Wix, Mobil1, or Bosch Filter. For cheaper, use filters lised but use maybe Mobil or Valvoline regular Oil
Old Mar 19, 2006 | 07:26 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Thanks!!!
First off, do NOT use Fram filters, they're junk Pennzoil filters are made by Fram, also junk. Wix, Napa Gold (made by Wix), Mobil1 (Champ labs), Purolater Pur1, K&N (Champ labs), and Bosch (also Champ labs, I think) are good filters. The best cheap filter is a WalMart SuperTech, it's also by Champ Labs.
For oil, the "best" and most expensive is real deal Grp 4 synthetics like Mobil1. Pennzoil Platinum synthetic is also good, ditto for Royal Purple and Amsoil. If you want to use conventional dino oils, Havoline is one of the best.
Best add-in oil treatemnt is Valvoline Synpower Oil Treatment (VSOT), it's loaded with very good adds.
Old Mar 19, 2006 | 08:03 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Depends on your driving. I personally don't like the orange can of death either, and the super techs are acceptable. Delco does not seem to be made by the same company anymore and IIRC Deutch may have been ok as well.
As far as oil, synthetic is better than conventional, however, you are the only one who can decide if it's what you want. AP cert oils are, well, AP certified. My preference is still Mobil 1, but I've been using Delvac 1 and Rotella T. I think I'm starting to lean towards those.
Old Mar 19, 2006 | 09:09 PM
Thank you so much I would of never known any of that b/c I used to drive a dodge dually and I put pennzoil in it...THANK YOU
Old Mar 19, 2006 | 09:35 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I keep hearing the Fram filters are junk. I know a bunch of racers who have high volume/high pressure oil systems that use them, none of them have ever had one blow on them. As close to "the truth" I've ever heard is they had some QC problems for awhile a few years ago, but have since solved them.
Don't think I'm an uncover spokesman for Fram. Personally, I never use anything but AMSOIL filters.
Old Mar 19, 2006 | 09:38 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Ah, the orange can of death just sounds good. That and their quality still sucks imo.
Shal we prod you for some info on Amsoil? That is one I should have listed. Actually, that brings on a question for a PM...
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
89 formula TPI
Sep 7, 2015 11:06 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
