Flat tappet cam users, read this
Old Mar 20, 2006 | 09:58 AM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
If you don't already know, the amount of zinc and phosphorus in todays oil has been drastically reduced, and is most likely causing flat tappet lifters to flatten cam lobes.
Here are some links about it.
http://www.revsearch.com/dynamometer...lattappet.html
http://www.powerandperformancenews.c...APNV2I10.htm#1
Old Mar 20, 2006 | 01:35 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
"Use a good racing synthetic like Amsoil 20W-50 Series 2000."
That's all you need to know. . .
Old Mar 20, 2006 | 01:51 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
That's been said since the last reformulations. Not really 'new' and I'm pretty sure it's been mentioned a few times recently as well. That's why a lot of us have been using delvac and rotella for break ins and then the delvac 1 and rotella T, Amsoil or Mobil 1 after break-in.
Old Mar 20, 2006 | 02:03 PM
five7kid's Avatar
It came up in the mid-80's even, with German Ford overhead cam 4-cyls. The Europeans didn't have the additive restrictions, designed the cams assuming the zinc was there, Ford paid for a bunch of engines before they figured it out. I know AMSOIL put more zinc in their 5W-30 at the time, although I haven't heard any issues lately. Of course, almost all OEMs are roller lifters, now.
Old Mar 20, 2006 | 02:09 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
SO we can use any oil with the GM EOS every oil change and be fine? Just asking because I still have 4 cases of 10w30 pennzoil in my garage.
Old Mar 20, 2006 | 02:13 PM
Damon's Avatar
GM EOS is magic stuff. One of the few "additives" that really does something helpful for your motor. Highly recommend for break in. Good to use even after break-in.
Old Mar 20, 2006 | 02:57 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Or use the Crane or Comp Cams break in additive for the break in period.
Old Mar 20, 2006 | 03:12 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
I read on BITOG that Valvoline Synpower Oil Treatment also has a great add package.
Alternately, use Synthetic or Diesel oils.
gta90
Sep 15, 2015 04:00 PM
camaro71633
Sep 1, 2015 10:24 AM
theurge
Aug 21, 2015 12:46 PM
LT1Formula
Aug 20, 2015 09:36 PM
anesthes
Aug 8, 2015 09:37 PM
