head bolt length
Old Mar 21, 2006 | 10:15 PM
bowtienick's Avatar
Car: 1991 rs, 1992 z/28
Engine: 363 ci chevy sb
Transmission: 700-r4
head bolt length
ok, im in the middle of building up my motor, and ive just recieved my arp head bolt kit. i had a problem- i had 32 bolts, but only 8 were the shorter length. i called them and got the right ones. now ive found i have all the same length long bolts. arent the two bolts on the ends of the heads by the oil drain back supposed to be shorter? im thinking of just sending in all the bolts i have now and re ordering. long story short how many different length bolts should i have
Old Mar 21, 2006 | 11:16 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I think you should have 3 different lengths.
shortest down low, by your exhaust ports
medium in the lower parts of the heads
longest in the taller part of the heads. not sure about the end ones, I didn't pay much attention when taking off my heads...oops
Old Mar 23, 2006 | 07:46 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
yep,there should be 4 mid length bolts for the corners.
Old Mar 24, 2006 | 10:34 PM
bowtienick's Avatar
thanks for the feedback. i called up summit, where i ordered them, and they called arp. they are getting this fixed up for me. both companies were very helpful.
evilstuie
Jan 9, 2020 08:29 PM
midge54
Dec 27, 2019 04:14 PM
355tpipickup
Aug 25, 2015 12:54 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
