help stop my crank
Old Mar 25, 2006 | 06:50 AM
pnutbailey's Avatar
Car: 1986 Iroc-Z28
Engine: stock 305
Transmission: stock 700r4
help stop my crank
I am installing a new harmonic balander on my iroc. I have the old one off but when i try to remove the tool from the end of the crank..... you guessed it . The crank turns. Is there another way to stop this without wedging something in the flywheel?
Old Mar 25, 2006 | 08:07 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Got an impact? It should hit it hard enough to free it.
Just the long bolt is still there?
If u have both the nuts on it you can try locking them together and trying to turn it that way or get them locked and use a wrench and hammer to shock it.
Borrow an elec impact, might work might not.
Or just chock the flywheel.
later
Jeremy
Old Mar 25, 2006 | 08:16 AM
pnutbailey's Avatar
Car: 1986 Iroc-Z28
Engine: stock 305
the pull bolt with the flanged nut is still on there. the balancer is off the crank but won't fit over the flanged nut. if i back the nut out all the way, i still have no way of stopping the crank from turning.
Old Mar 25, 2006 | 11:31 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Get a flywheel turning tool and pull the inspection cover from the front of the bottom of the tranny, let it bind against the tranny case in the direction you're turning the front of the motor.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
KCG
Jun 24, 2020 04:33 AM
MM2Robinson
Oct 1, 2017 09:16 AM
85 Jimmy
Sep 30, 2015 07:56 AM
383cam
Sep 9, 2015 06:01 AM
