I have a question...
Old Mar 25, 2006 | 03:32 PM
rjpbboi's Avatar
Car: 87 Trans Am, 89 RX7
Engine: 350tpi,350carb
Transmission: T-5,t56
Axle/Gears: 3.42 Posi,4.11 posi
I was just talking to some of my friends the other day about this kid in our grade who went a crazy amount of miles without an oil change, like 13k or somthing like that. My friend harry pointed out that if you don't change the oil for a long time and then you change it, it could blow the motor. I don't really understand the logic of this, but seeing that his dad owns and operates a garage, I figured I'd ask you guys to find out if this is true or not. Thanks.
Old Mar 25, 2006 | 03:56 PM
DLV555's Avatar
Car: 1987 Monte Carlo SS
Engine: 400 SBC
Transmission: 200-4R
Axle/Gears: 4.10
No way. Putting new oil with fresh friction modifiers and other additives in the motor can't be bad for it. But if you go a few oil changes stretching it out to 13k miles then some damage may already be done to it.
Old Mar 25, 2006 | 04:26 PM
ljnowell's Avatar
Originally Posted by rjpbboi
was just talking to some of my friends the other day about this kid in our grade who went a crazy amount of miles without an oil change, like 13k or somthing like that. My friend harry pointed out that if you don't change the oil for a long time and then you change it, it could blow the motor. I don't really understand the logic of this, but seeing that his dad owns and operates a garage, I figured I'd ask you guys to find out if this is true or not. Thanks..
Your friend is a tard.
I think he may be confusing engines with transmissions. I have seen lots of auto trans that didnt get a filter and fluid change until 140-150, get the flush and then die.
Old Mar 25, 2006 | 06:03 PM
joe350's Avatar
Car: 91 Z28
Engine: 350 TPI (L98)
Sometimes changing the oil on a particularly grimey engine will "clean out" places that are using the dirt/oil cake as a sealant. I've seen this happen in places like valve cover and oil pan gaskets, but as far as causing the engine to blow, I really doubt it.
Old Mar 25, 2006 | 06:05 PM
rjpbboi's Avatar
Yeah, I didn't think it could be true, thanks for clearing that up.
Galaxie500XL
Oct 1, 2015 01:05 PM
happyhapka
Aug 15, 2015 04:42 PM
ebmiller88
Jan 28, 2002 09:51 AM
KlayBuRn
Car Audio
Aug 30, 2001 12:52 AM
Lotsokids
Carburetors
May 28, 2001 08:42 PM
