temp gauge not working not a sender
Old Mar 25, 2006 | 06:08 PM
z28z34man's Avatar
Car: 1984 z28 camaro / 2019 accord sport
my temp gauge has not ben working for some time now so i just replaced the sender and that did not solve it. i would do a serch if there was one
Old Mar 25, 2006 | 06:19 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
sender should show a resistance value based on the temp it is reading, I forget what ohm-age represents what temp, but that's one thing to check (make sure the sender is outputting correctly). Then you probably have an open circuit between the head and your cluster. You can try removing your cluster, and checking the wiring, see if something is dirty/corroded, or broken.
Old Mar 25, 2006 | 06:22 PM
z28z34man's Avatar
k the said thing is that i am in college to be a electrical tech and i don't have a dmm so i am buying one on e-bay right now
Old Mar 25, 2006 | 06:40 PM
Sonix's Avatar
Car: 1982 Trans-Am
ha-ha!
why not grab one from your local parts store for $12? At my company (circuit boards) we use continuity and voltage basically. Every now and then, resistance. No other fancy shmancy features.
Old Apr 2, 2006 | 03:05 PM
z28z34man's Avatar
well i got my dmm from e-bay and i have 69 ohms with the wire disconnected from the wire to ground
Old Apr 2, 2006 | 04:28 PM
Vader's Avatar
Ignition ON, what is the open circuit voltage at the sensor wire?
Old Apr 2, 2006 | 04:30 PM
z28z34man's Avatar
ignition off if it where on there should be voltage and that would throw the reading
Old Apr 2, 2006 | 06:46 PM
Vader's Avatar
Yes, that is what I am asking. With the connector disconnected from the sensor and the ignition turned ON, what is the voltage at the connector (not the sensor)?
Old Apr 3, 2006 | 11:59 AM
z28z34man's Avatar
o ok i will test it tonight
Old Apr 3, 2006 | 05:56 PM
z28z34man's Avatar
with out it running 12.11 volts
Old Apr 3, 2006 | 07:52 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Transmission: Tremic6060
Axle/Gears: good enough
the gadge its self could aslo be bad (mine was) if your gadges are anything like my 83's all you have to do is grab a jyard gadge (make sure the needle is good, sorta hard to explain how to tell if the spring is good, if your needle in your car is past 260 degrees and doesnt go down, then the spring is bad) If you can get a PNP one it will be 10X cheaper.
Ghettobird52
Jul 5, 2024 11:18 PM
Jeremys87
Jul 14, 2022 09:08 PM
NBrehm
Aug 25, 2015 11:49 PM
justin57
Aug 20, 2015 07:05 PM
bamaboy0323
Aug 15, 2015 07:20 AM
