383 project (what cam?)
Car: 87 trans am
Engine: 357 ci chevy engine
Transmission: th350
i got a 350ci and i will stroke to 383 but the 350ci cam will not fit
i need a small cycle cam or whaever calls cam to fit the 383ci
what cam fits?
please
brand
model (part number)
BTW
MY ENGLISH IT PRETTY BAD!!!!!
what cam fits?
please
brand
model (part number)
BTW
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
What heads do you have?
What size valves do they have?
What intake do you have?
What gears do you have?
What is your exhaust system?
Will you drive the car every day, or is just for racing?
What compression do you have?
Car: 91 Z28 CAMARO
Engine: 383 STROKER TPI
Transmission: TH-700-R4
do u want low end or mid range cam
i have a 282/282 with 480/480 lift in my stroker which is a mid range cam
Car: 87 trans am
Transmission: th350
128 fully ported
1.94 1.50
edelbrocki torker 2
3.73
headman heders and 3' custom catback
weekends
10.5:0 to 11.7:0
128 fully ported
1.94 1.50
edelbrocki torker 2
3.73
weekends
10.5:0 to 11.7:0
Car: 1991 Z28 Vert
128 fully ported
1.94 1.50
edelbrocki torker 2
3.73
weekends
10.5:0 to 11.7:0
128 fully ported
1.94 1.50
edelbrocki torker 2
3.73
weekends
10.5:0 to 11.7:0
Those small valves combined with a long stroke and lower flowing heads will probably need a cam on a 110-108 LCA. If you have 11.7 compression, go with the 108 LCA. If the compression is 10.5, go with a 110 LCA. I would not go above 110*.
Since it is a stroker it will also need to be a cam with a small base circle.
The exhaust on that cam will need extra time to flow through that exhaust system. Look for no less than a 10* seperation for exhaust.
I would look for a cam with an intake duration around 220-224. With exhaust at 230-238.
Since you have 3.73 gears, I would go with a better intake, like an RPM or such. You will rap out that smaller cam pretty quick. You could go with a bigger cam if you had n intake more suited for higher RPM or better flow.
gixxer92
Sep 1, 2015 04:32 PM
LT1Formula
Aug 20, 2015 09:36 PM
