Fuel and teflon tape
....I'm installing a new set of braided fuel lines and fuel pressure gauge on the fuel rail of my L98.
Do I need anything special like teflon tape, or do I just tighten down the lines like normal?
Thanks,
-Boob
Thanks,
-Boob
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Thread sealant with teflon on any NPT-tpye thread, no sealant required on any AN's flared fittings. That's how I plumbed mine. No known issues yet. People have used teflon tape in fuel systems and it works fine. I, personally, do not like to use it because of the chance a loose end can block something up, especially at the higher pressures that the TPI systems run.
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I have found that if I do not let the sealant dry for at least a few hours, I can still get leaks with it. So make sure it is dry.
92camaroJoe
Aug 13, 2015 06:07 AM
